Erreurs rapportées dans mise à jour
jimmy44
Message par jimmy44 »
Bonjour :D !
Lorsque j'actualise le gestionnaire de mise à jour , je reçois des informations que je ne comprend pas .
W: Target Packages (main/binary-amd64/Packages) is configured multiple times in /etc/apt/sources.list:2 and /etc/apt/sources.list.d/additional-repositories.list:1
W: Target Packages (main/binary-i386/Packages) is configured multiple times in /etc/apt/sources.list:2 and /etc/apt/sources.list.d/additional-repositories.list:1
W: Target Packages (main/binary-all/Packages) is configured multiple times in /etc/apt/sources.list:2 and /etc/apt/sources.list.d/additional-repositories.list:1
W: Target Translations (main/i18n/Translation-fr_BE) is configured multiple times in /etc/apt/sources.list:2 and /etc/apt/sources.list.d/additional-repositories.list:1
W: Target Translations (main/i18n/Translation-fr) is configured multiple times in /etc/apt/sources.list:2 and /etc/apt/sources.list.d/additional-repositories.list:1
W: Target Translations (main/i18n/Translation-en) is configured multiple times in /etc/apt/sources.list:2 and /etc/apt/sources.list.d/additional-repositories.list:1
W: http://download.ebz.epson.net/dsc/op/stable/debian/dists/lsb3.2/Release.gpg: Signature by key E5220FB7014D0FBDA50DFC2BE5E86C008AA65D56 uses weak digest algorithm (SHA1)
que faire pour régulariser ?
Merci d'avance !!!
Modifié en dernier par débitant le lun. 13 nov. 2017 11:49, modifié 1 fois.
Raison : ajout des balises "code" pour faciliter la lecture du sujet
Linux Mint 18.2 Cinnamon 64 bits. 4.8.0-53-generic x86_64 (64 bit gcc: 5.4.0)
Hewlett-Packard (portable) product: HP G72 Dual core Intel Core i3 M 350
Re: Erreurs rapportées dans mise à jour
salut.
sudo rm /etc/apt/sources.list.d/additional-repositories.list
sudo update
jimmy44
Merci .. Il reste : W: http://download.ebz.epson.net/dsc/op/st ... elease.gpg" onclick="window.open(this.href);return false;: Signature by key E5220FB7014D0FBDA50DFC2BE5E86C008AA65D56 uses weak digest algorithm (SHA1) ... Mais mon imprimante Xp-610 fonctionne nickel en Wifi.
:oops:
Bonjour Jimmy.
[edit] Post effacé par l'auteur, voir solution de Mpat ci-dessous.
Modifié en dernier par alain le mar. 14 nov. 2017 04:49, modifié 1 fois.
salut, ta clé c'était pour epson tu n'en as plus besoin.
sudo rm /etc/apt/sources.list.d/epson.list
trouvé chez debian.
ATTENTION : Si vous avez correctement configuré votre fichier personnel '~/.gnupg/gpg.conf', il est très possible que vous ayez ce message d'erreur concernant la clé GPG fournie par Epson :
Cela signifie simplement que leur clé a été créé avec le protocole par défaut SHA1 ... bref, une clé peu fiable -
vous ne devriez probablement pas l'utiliser, mais c'est le seul moyen fourni par eux ; à vous de voir, si vous voulez lui faire confiance ; en tout cas, ne signez pas une telle clé !!!
